PRC 227 heads, lifter & pushrod question
I bought a set of PRC 227 heads earlier this week and I could not find much info on lifter & push rods setups. I will be running MS4 cam, Yella Terra rocker with the stock 1.7 ratio with LS7 lifters. Now I know I can run LS7 lifters with the stock length push rods 7.40. Now will the new 227 heads affect my push rods or will my 7.40 work ? just want to get a general idea what people are running.
Thanks !
Thanks !
Measuring is definetly a good idea. U should also give Texas Speed a call and tell them what your valvetrain setup is and they could give you a good idea on what length pushrod youll need.
The 227's have a thicker deck like tfs. So if everything in a perfect world you would be at a 7.5 pushrods. The ls7 lifters i beleave use less preload. Your probably looking at 7.475 to 7.5 rods. Spend the $20 and measure.
