LQ4 Build, milling 317s
Old 02-19-2011, 10:20 AM
sman's Avatar
Default LQ4 Build, milling 317s
Picked up a low miles lq4 yesterday, so far just have the intake off. But I pulled a valve cover and man does it look clean, like brand new, theres marks from a paint marker on the inside of the valve cover, on all the springs, and the inside of the head, looks promising!
Will be running stock bottom end.
I want to use the 317s as I can get them milled for nothing, literally. My question is how much to mill these guys?
Stock for stock, they flow the same numbers as 243/799 castings, or so im told, but with bigger chambers. The 317s have 72cc chambers, where the 243/799s have 64cc chambers. Obviously I want to get them as close to 64 as possible, but thats just not happening. If I use the math that .007 milled is 1cc, then to get to 64cc id have to mill .050+, just not possible.
But if I mill to much im going to kill my valve clearance.
Trying to get this figured out asap, id like to get the heads to the shop today if I can.
Old 02-19-2011, 12:06 PM
Turd Gen Guy
1nasty86's Avatar
i believe 6 thousandths= 1cc. my 317 heads are milled to a 64cc chamber also... so thats roughly 48 thousandths you have to cut off.
Old 02-19-2011, 12:42 PM
sman's Avatar
What cam are you running? I cant believe you not having PTV issues.
What kind of power are you making?
Did you have to machine the intake to get it to work?
Old 02-19-2011, 01:08 PM
Turd Gen Guy
1nasty86's Avatar
mine are t.e.a. Stage 3 317's with stock thickness head gaskets and pat g. Spec'd my camshaft its a 230/238 .600/.604 112+2. Havent been tuned yet and I found out my pushrods are too short but I trust pat g and his spec's.
Old 02-19-2011, 05:56 PM
NemeSS's Avatar
Try to keep around .030 any more can cause manifold/heads alignment issues. Plus affect ptv clearance
Old 02-19-2011, 10:50 PM
sman's Avatar
Just took an interesting turn, was pulling the 317s from my newly acquired motor today, and found out my lq4 is not an lq4..... Its an lq9! I was pleasantly surprised to find flat top pistons in this thing!
I was thinking about milling 0.030, but now I dont know what to do now that I cant count on dished pistons helping me in the PTV department. If I did the math right, milling the 317s to 67ccs (0.030mill) would get my 10.5 : 1 CR. What size of cam would I still be able to get in there? Roughly, just trying to get an idea. Would a TR 224 work? Any thoughts on the power output with that and mods in sig?
Thoughts?
Quick Reply: LQ4 Build, milling 317s
