what head gaskets to get? 5.7 or 6.0
I have looked around a little but what head gaskets should i get for a lq4 that im putting 99 ls1 heads on. Should i get 5.7 head gaskets or should i get 6.0 gaskets? Thanks in advance!
The gasket always matches the bore .
Sometime people use 4.000 bore gasket in their LS1 3.900 bore , I dunno know why but maybe because of having larger valves (2.04 or more) , that what I thought .
Anyone have another reason ?
Expl: 6.0 heads on 5.7 motor, use 6.0 gasket; 5.3 head (stock) on 5.7 motor, use 5.7 gaskets etc....
What about having 243 ported heads with 6.0L gasket ? what reasons make this happen ?
Same with like using 6.0 heads on a 5.3L The head chamber is bigger than the bore, so you want to make sure the fire ring is enclosed....you'd need 6.0 gaskets.
