What do you think of my setup
So far this is the setup I want to go with tell me what you think of it and any est. hp/tq ratings
408 ci
lq9 bored
callies compstar 4 " crank
Callies Ls C Rods 6.125
Diamond -2 valve relief flat tops 4.030
Cometic gasket 4.030 stock thickness .051
68cc 317 with valve job
for now I will be using a stock ls6 intake and ported tb...
any input is appreciated thanks!
408 ci
lq9 bored
LS1Tech Premium Sponsor
Are the heads going to be worked any aside from the stated milling? Obviously you already know your intake combo is going to hold you back some. Need a bit more info to make any suggestions or estimates at power level
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
as far as a valve job probably not... my budget isnt letting me do much yet to it
