Motor Questions, Whats this worth? And what kind of power am i expecting???
Someone i met has this motor and its never been ran its brand new......Curious what everyone thinks about it and what to expect? Was going to build up mine but i might make an offer on this motor. it also has a fast intake for those who were curious.
LS1 Build Sheet
16 Roller Rocker Arms
1 Custom Cam 581-588 / 224-230
16 Hydraulic Roller Lifters
16 Pushrods HP 1 Pc Kit $1,150.00
2 M2 Race Systems $2,100.00
CNC Ported GM Heads LS6
Complete 317 cfm intake
220 exhaust
1 Melling HV Oil Pump $190.00
1 LT98533 Timing Set (Specifics Needed) $109.00
1 Oil Gasket Set
1 Head Bolt Set $200.00
1 Labor to assemble top end $300.00
1 Clean Block – Check
1 Pressure Test – Line Bore
OK $120.00
1 Clean check crank OK
1 Eagle Kit
9.8 Compression Part No. 12804 – 383 CID $2,400.00
1 Balance and Assembly $300.00
1 Bone Hone Block $300.00
1 Deck on Blue Print $150.00
1 Assemble C-R-P $350.00
Last two lines are illegible
Total: $7,669.00
Asking Price: $7,669.00 x 70% = $5,368.30
LS1 Build Sheet
220 exhaust
1 Oil Gasket Set
OK $120.00
1 Eagle Kit
Total: $7,669.00
