ms3 or ms4 cam ls6 heads 1.0 or 2.5
i have decided on a ms3 or ms4 cam for my 01 trans am 6speed. whitch setup wont have ptv clearence prob. ms4 with ls6 stage 2.5 heads or ms3 with stage 2.5heads. or would the ls6 1.0 heads be beter for ptv clearence. witch heads would you guys rec with the ms3 or ms4 cam. thanks have longtubes and suporting mods done already. thanks for thelp guys.
What kind of budget are you on and do you plan on having the heads milled to bump compression or anything. Just curious on what your looking for out of this build. You should definety give Texas Speed a call and they should be able to get you the answers your needing.
LS1Tech Premium Sponsor
^^This guy has the right idea! Are you wanting the best piston to valve clearance, or best performance? What other mods are on your vehicle? What goals do you have for this swap (HP, torque, ET's, etc)?
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
What power are you making now with the stock heads/cam combo?
__________________
Ive been looking into this also and I keep finding mixed info on the MS4 cam needing to have the pistons flycut or not. I am currently building a late year corvette ls1 block with flat top pistons and stock(not milled) 243 heads with patriot extreme springs and stock ls2 intake. I have a MS4(111 lsa) cam sitting here for when I get the block back but Im not sure if I should change cams or not. Im thinking the tqr v.3 might be better suited for my mild build.
what do you guys think of the 5.3 heads stage 2.5 heads. the valves are larger than the ls6 1.0. will it have more compresion istent that better? the larger valves whould make ptv clearence even tighter? what do you guys think. ls6 1.0 or 5.3 2.5 heads.
