New build 404ci afr 225, need bits and pieces.
So im trying to get a full list of stuff I need to complete my motor. I have a rotating stroker assembly, block and heads. Im listing off everything I have, then what I need, please chime in with something im forgetting. I have never pieced together a motor before, so I know I WILL forget something. Most important things are the ones the machine shop will need to complete the shortblock. I want to have this thing in the car so I can start work on my subframe. Chassis easily flexed with a stock 5.3l on its maiden voyage, so it needs serious reinforcement. I want to to be able to remove the oil pan, and tranny w/o pulling the motor, but still have the most structural support as possible. A roll bar with the possibility of a roll cage will help with the stiffening.
Details on the build are as follows: 6.0 iron block bored to 4.010. precision stroker crank, TSP diamond -15cc dished pistons, lunati rods, arkly and childs xtreme rings. For heads I have a set of afr 225’s that will be milled down to around 59-60cc chambers. The block was spec’ed out for a twin turbo build, I purchased it and have no need for more than 500rwhp on a regular basis, so im going to mill the heads to make up for the large piston dishes.
I had a fully running setup, then pulled the longblock w/o intake or pan. So I have all the acc and everything else needed to run.
Once its all up and running, i may merge this thread into my car's build thread, and add dyno sheets. Car will be tuned by Don Slowhawk Performance, and motor assembled by Jim Reid, at Reids automotive.
What I have:
Heads [complete no rockers]
Block Machined already!
Crank
pistons
rings
Rods
Rod bearings [clevite 77]
Cam bearings installed in block
Oil pan
Front and back covers
That little white barbell thing for oiling system[what is this by the way?]
What I need for short block assembly:
Front cover gasket _______GM Part# 12633904
Rear cover gasket _______GM Part# 12633578
front cover bolts _________GM Part# 11515758 M8x1.25x30
rear cover bolts _________GM Part# 11515758 M8x1.25x30
Ls7 Lifters ______________GM Part# 12499225 all 16
Cam
Lifter retainers __________GM Part#12551162 uses 4 of them.
Main bearings
TSP ls6 ported oil pump ___TSP part# 25-12586665M
timing set with chain _____TSP part#11-1160 Rollmaster heat treated double roller
LS6 valley pan __________GM Part# 12568002 [According to ls1howto.com this includes the gasket and the bolts!]
Valley pan gasket _______GM Part# 12558178
Vally pan bolts __________GM Part# 11515758 M8x1.25x30
Oil pan gaskets _________GM Part# 12612350
What I need to complete the entire motor:
Head gaskets___________GM Part# 12589227
Rockers
pr’s Don't know the length i need, so i will have to purchase post assembly.
Head bolts/studs _______TSP Part# 46-134-3609
valve covers Prob get through the classifieds.
Sensor list
Knock sensors[Qty 2] ___GM Part# 12589867 Part#'s Delco # 213-362, BWD #S8696 , Duralast #SU1282
Kock sensor wire _______GM Part# 12601822
Cam sensor ___________GM Part# 12561211 Part#'s Delco # 213-363, BWD #CS1531, Duralast #SU1277
Crank sensor __________GM Part# 12560228 Part#'s Delco # 213-354, BWD # CSS142, Duralast # SU1178
Coolang Temp sensor ___Part#'s 2 pin design- .Delco # 213-953, Duralast #SU112, Everco # 36419, BWD , #WT5132
Air intake temp ________Part#'s Delco # 213-243, BWD # W3036Z, Duralast # SU176
If you have part numbers for the generic stuff I can get strait from a dealer please list them. If you have part numbers from stuff not from a dealer, please list only if they are a sponsor!!!! Im going to update this post with numbers, im sure someone else could benefit from this.
What I have:
Crank
pistons
rings
Rods
Oil pan
Cam
Main bearings
Rockers
Sensor list
Last edited by Marcello7x; 03-01-2011 at 06:57 PM. Reason: Added more part numbers.
Ordered everything minus head gaskets!. Waiting on tony from afr to give me some info about head milling so i know whether or not i can run stock gaskets and get my desired cr.
