Tu1 cam springs?
Tu1 cam springs?
Im just wondering what springs I should use with the Speed inc Tu1 cam. The specs are 225/225 581/581 113. this cam will be used in my single turbo ls1 build with 7-9lbs of boost. thanks
I was looking at the pac single springs and they are good up to 650 lift and will use the factory spring hardware. Is this ok with a single turbo? Or should I use a double spring. Only running 7-9 lbs of boost
what about the pac 1218s? would that be decent enough to hold a TU0 or 1? i seem to keep geting those coming up alot. those are single beehives as well for up to .600. would these be ok or is that cutting too close for the lift of the TU0 and 1 with .581?
