Is the LS6 cam better than the LS1
Old 02-15-2004, 09:00 PM
cgworth's Avatar
Default Is the LS6 cam better than the LS1
Is the stock ls6 cam and springs better than the stock LS1 camm and springs or are they the same. if they are, How Much? here is the info i could find on the cam but im not that good on looking at the numbers yet can anyone tell me if there any good .550"intake and exhasut lift-218 degree exhaust duration, and 204 degree intake duration at .050, and 117.5 degree lobe centers also is it worth buying one or going with an after market i can get the cam new for $189
Old 02-15-2004, 09:07 PM
NviouSS's Avatar
from the info i've been gathering about cams, the LS6 came makes its power in the upper RPMs. i've read that you pick up around 30 rwhp from the cam. i'm not sure about the springs though.
Old 02-15-2004, 09:09 PM
98SS Blackattack's Avatar
Yea its better. Avg is around 25hp. The springs are better too. Good to around .55X lift.
Old 02-15-2004, 09:48 PM
cgworth's Avatar
to the top
Old 02-15-2004, 09:49 PM
poncho99's Avatar
Default cam shaft
dont waste the money on the cam i have one right now in a99 t/a it's comming out with in a week or two cant tell any difference at all.
Old 02-15-2004, 10:05 PM
99 Black Bird T/A's Avatar
Received 1,432 Likes on 992 Posts
In area under the curve the LS6 cam can put about ~50rwhp on the LS1 cam in the upper end of the rpm range around ~6,000 rpms. The peak gain is ~23 to 25 hp.
JMX posted a dyno graph that showed this.
Old 02-15-2004, 10:23 PM
The thread
https://ls1tech.com/forums/generation-iii-internal-engine/105849-ls1-vs-ls6-cam-dyno-graph.html
Old 02-15-2004, 11:04 PM
2xLS1's Avatar
Here is another one.
Old 02-16-2004, 01:10 AM
jrp
SN95 Director
jrp's Avatar
did you raise your rev limiter? if not then of course you wont notice a gain as the ls6 cam peaks alot higher then the ls1 cam.
the ls6 cam aint my style but its a great plug and play cam that requires minimal tuning if any and has greater top end pull provided you raise your rev limiter to obtain it.
Old 02-16-2004, 07:26 AM
poncho99's Avatar
yes i raised the rev limiter to 6500 even had it dynoed still wasn't impressed with the # went from 303 to 311 rwhp.that also with slp lone tubes no cats and a ls6 intake.
Old 02-16-2004, 08:19 AM
Do you have a dyno graph? Something isnt right.Are you sure it was installed dot to dot, i bet its off a tooth.
Old 02-16-2004, 11:35 AM
JZ'sTA's Avatar
I bet its off as well or your running about 10.0 Air Fuel ratio.
Lean that bitch out, and if that isn't the problem then your cam is probally off.
I have seen 3 installs in person and the least amount of power picked up was 20 RWHP. The whole curve had more power as well.
I have also seen at least 8 header install's, probally 5 being LT headers. The least amount of gain here was 17 RWHP through stock exhaust. Highest was nearly 40 but that included exhaust at the same time. Avarage is about 21 I would guess.
As far as the Z06 intake goes I have only seen 2 guys do these without anyother mods being done at the same time. A gain of 4 on one and 7 on the other.
If you take all the lowest numbers I just wrote about you would have gained 41 RWHP.
Something's way wrong
Old 02-18-2004, 10:58 PM
ZtwentyATE's Avatar
I have this cam an it was a hell of alot more than a 11 rwhp gain. I had it tuned with the Predator and the difference was of "holy ****" caliber. I felt a increase starting at 4,000 rpm and 5,000+ is just nuts compared to the stock truck cam. Kinda wierd watching it shift at 6,500 rpm, but it makes power all the way to it. I have no regrets.
Old 02-19-2004, 06:24 AM
dheck's Avatar
I had the LS6 cam. It was a good sleeper cam but I wanted something bigger. If you are looking for huge gains and large number then go with something different.
