ls6 heads and trick flows cam $1100
im thinking of buying this set from someone wanted to know if its going to be a good by all i want is 400rwhp will this help me
243 heads and a trick flow cam package, These heads just came from the machine shop everything was inspected, There are 5,000 miles on the heads, I just put new comp cam springs and I have new comp cam push rods for the package, The trick flows cam is 228/230 duration .585 lift. Everything is almost new. Tested it on the dyno gave my ss camaro with als1 over 400hp. The heads also come with new valve covers and valve cover gaskets
my ls1 is in a 67 camaro i have an ls6 intake slp mafs ported tb sanderson short headers thats all i have and with that addition im hoping to see 400hp with good gas milage you think that is a good buy?
thanks
lou
thanks
lou
