info on 823 cast heads
Im a new owner of a 2001 SS Camaro, I bought a 6.0 that has 823 cast on the heads.Im goin to stroke this motor and was wandering if these heads are worth a flip or should i go with after market heads ?
Ls3 intakes go for about 300 with injectors and no throttle body, you can put ls3 valves in the heads, the weight less. There is nothing wrong with the stock heads though. I am using the stock heads.
