Torquer v2, cam only
Will I be ok running Comp 918's? I have a stock 01 LS1 pullout. I was gonna do the stock push rods etc, just the cam and springs. But I know it is pushing the limit of the 918.
It had TTS headers, Yank SS3600, Built trans, 3.73's, LS6 intake, ASP pulley.
After all the bad batches of 918 springs I cant beleive people still use them..PAC makes great single beehive springs with no bad history...myself I always use a dual spring ... I ran a set of PRC duals on my torquer cam for about 45,000 miles before I changed to a different cam..the springs were still within spec when I changed them.
PS The stock GM pushrods are a joke and barely control the stock valve train..running a stock pushrod on the torquer cam would not be wise. Quality aftermarket pushrods will not cause you to drop a valve...who told you that BS.
PS Milk has and experation date I have never seen and experation date on a valve spring...poor anaology dude...
