What you all think of this cam on the street...
http://www.texas-speed.com/shop/item...d=168&catid=44
Wont be seeing the track for a good while. But wanted some fun on the street. My newest motor has 241 heads, ls6 intake, slp lm1, pacetter headers. Just replaced the springs with the prcs good too a .650 lift. Was wanting to get the 112lsa. This car will be drivin someitmes to play around and maybe 20 miles back and forth from work on days its nice. I know ill need a tune but just to putt around you guys thing it will be ok to drive for awhile and get on it from time to time before the tune?
Thanks all!!
-Travis
Thanks all!!
-Travis
410's or 430's at least. DEFINITLEY a tune or you'll buck and surge enough to want a Cowboy hat. VERY fun cam. I have it on a 112. I daily drive it and love it. Sound clips in the sig.
I got 410s sorry forgot to put it. Now my old setup I had was tuned for a cam almost the exact same size so u think I will AS soon as I put it in if my comp was tuned for a decent size cam before?
nice choice of a cam, will behave pretty good on the street.
i was torn between the V2 and the MS4 , but i finally went ms4.
like said above , you can drive without a tune at your own risk , but dont go WOT untill you can get a tune.
while your swaping the cam, you might as well swap the oil pump...lingenfelter makes a nice unit that will not break the bank. might as well upgrade the timing chain just to be sure , cant hurt right ?
i know you said you have the prcs springs , you might want to look into pushrods if you havent allready.
i had about 1500 to swap out the motor i found. Well my original plan was too use my valve springs, and cam for the newest motor i bought. BUT two springs were busted, and the cam was chewed up some from the piston i guess. Soooo had to find bout 750 for the new springs, and the newest cam. The oil pump and timing chain will have to come at a later date. But before then it will get tuned about the beginning of the month.
