Lq9 bored 60 over stock heads
i have a ? i have a lq9 bored 60 over will it be ok to bolt on my stock 853 heads just for a while till i get better heads will it run ok they are mildly port n polish dual springs comp cam rockers
Can you afford ls6 heads? If so I would get a set of those. If not the you would have to steo up to 241 heads minimum because that will require a ls2 head gasket and the 853s take a special gasket that I don't think come in a 4.0 bore spacing or 4.060 in your case.
