Part Number list for PRC 5.3L heads (Help Please)
Old 03-09-2011, 09:19 PM
NTIMD8's Avatar
Default Part Number list for PRC 5.3L heads (Help Please)
Okay so I am starting with a 1998 LS1 and am doing a head swap (PRC stage 2.5 5.3L).
Can you guys help me with my list by either confirming any part numbers I list below, providing ones that are missing or listing anything else I will need to do the swap. This thread should also help people in the future since I did a search but came up short.
1- 5.3L Center Bolt valve covers (getting this from a salvage yard)
2- 5.3L Center bolt valve cover coil pack brackets (getting this from a salvage yard)
3- Valve cover gaskets for center bolt valve covers (Felpro VS50504R)
4- Head gasket (stock thickness) (GM head gaskets or Felpro Head Gasket) Anyone know what part numbers would be? Is the 5.7L and 5.3L head gasket the same ones?
5- Head gasket bolts (GM # 12498545 since it is for a pre May 2004 LS1)
6- ??? (anything I am missing?)
Thanks for any help!
J
Old 03-10-2011, 02:23 PM
TXZ28LS1's Avatar
Since you are going with PRC heads from TSP you will get a better and quicker answer just calling them.
Old 03-10-2011, 02:39 PM
Z28/2002's Avatar
Location: Your girl's back door giving her the long stroke while you're at work
Get the valve covers and coilpack brackets off here, get everything else from TSP
Old 03-10-2011, 03:05 PM
Jon@Texas-Speed's Avatar
I would try and find the valve covers and backets used. The new ones are pretty high from GM. Here's the part numbers on those items:
GM Valve Covers: Left - 12570427, Right - 12582224
Coil Brackets: 12563288
Gaskets: 12637683
Heads: 12498544 (MLS)
We should have it all here ready to go!
Old 03-10-2011, 08:26 PM
NTIMD8's Avatar
Texas speed and performance ******* rocks! You guys are always willing to help out and your products are top notch!
Quick Reply: Part Number list for PRC 5.3L heads (Help Please)
