cam bearing fell out! what now?
installing a cam in a 6.0 (it is on a stand with heads and oil pan off) the #2 cam bearing fell out when putting the new cam in. Im hearing that the whole bottom end has to come apart for a machine shop to put new cam bearings in. Is this true? If not can i put new bearings in my self? how hard is it? Whats a normal price for a shop to install them?
You can replace yourself. Get a cam bearing tool. Measure the OD of the bearing that came out & make sure that the one that replaces it is larger in OD. BTW, cam bearings pre-04 are different than cam bearings post 04 & they are specific to install location. So, you must pay attention to which bearing gets installed into which location. Someone may have installed the srong bearing in #2 previously.
