Stock 03 Z06 243's piston clearance?
Old 03-13-2011, 07:34 PM
usmonaro's Avatar
Default Stock 03 Z06 243's piston clearance?
I've got an 04 gto that these are going on. I'm going to put PAC .650 lift beehives springs on them. When I was reading earlier it said that the 02-04 with lightweight valve had longer stems. Do you guys know if I'm going to Have any issues with this setup and a torquer v.2 cam. .595/.598? Thanks you guys.
Old 03-13-2011, 07:40 PM
bayer-z28's Avatar
^ unshaved, you'll be fine. It's the duration that could create PTV issues. I'm running 04 243 heads now with those valves. 228 duration with .639 lift.
Old 03-13-2011, 10:10 PM
usmonaro's Avatar
Thank you. Ill check my duration but I don't think my cam is that large. Any ideas towards the duration limits? I hope mine don't exceed yours lol.
Old 03-13-2011, 10:24 PM
PREDATOR-Z's Avatar
TV2 will fit if heads not milled, you'll need to measure for pushrod length.
Old 03-13-2011, 10:26 PM
wickedbluess's Avatar
i ran that cam with stock 243s and had no problem.
Old 03-13-2011, 11:06 PM
usmonaro's Avatar
What pushrods did u guys run. Tsp told me the 7.400's would be fine.
Old 03-14-2011, 07:38 AM
bayer-z28's Avatar
^ Grab a push rod length checker to be double sure it's correct. Take the measurement and add .050 - .075 for lifter preload.
Old 03-14-2011, 09:52 PM
i ran 7.4s but its always good to double check
Old 03-15-2011, 01:59 AM
PREDATOR-Z's Avatar
If those are LS6 valves, they do have longer stems and that IS why you really need to measure to get proper preload.
Old 03-15-2011, 02:22 AM
MotoFreak's Avatar
also ran it with that cam, had no problem!
