Hybrid 5.3L ????
Old 03-20-2011, 07:04 PM
Dans93S10's Avatar
Default Hybrid 5.3L ????
Sorry might be a stupid question but I really dont know much about LS series yet... I'm reading every chance I get, So on to my question. I'm looking for a 5.3 to do a swap into my 1st gen S-10 and I have seen acouple 5.3L's that came out of the Hybrid trucks, now are those they same as a 5.3L that is in a normal silverado??? I have asked acouple of people I know and no one was really sure and I dont want to waste my money on a block I cant use. Thanks for any info in advance.
Daniel
Old 03-20-2011, 08:12 PM
nodrok's Avatar
I dont believe there is any difference. Even if there was it nothing major so minor changes would net you similar results.
Old 03-20-2011, 09:50 PM
Bo185's Avatar
The early hybrid 5.3L was a regular 5.3L with the hybrid parts being in the flywheel of the trans.
Old 03-20-2011, 09:54 PM
Awake455's Avatar
Well now...the notion of a 5.3 hybrid S10 sorta prompts me to pondering. I suppose if a person could get everything cheap enough from a donor truck it would be interesting to see how it does on mileage. Not sure it could be done cheap enough to prove worth the effort and pay off given the added complexity.
Old 03-21-2011, 10:01 AM
Bo185's Avatar
Not really worth it. The only mileage increase would be city mileage. It would not effect hwy miles it would be the same a a normal motor.
Old 03-21-2011, 02:43 PM
Dans93S10's Avatar
Thanks again. Everyone I talked to have said the same thing. Now all I really gotta do is get a 5.3L or just step up the the big boys and run a 6.0L like I really want to, just so hard when the 5.3L's are much cheaper.....
Old 03-21-2011, 05:12 PM
Bo185's Avatar
The good thing is you can buy a 5.3L swap in for cheap run it. Then buy a long block 6.0L, which will bolt right in place, later and all you need to do is retune it!
Old 03-21-2011, 06:52 PM
Dans93S10's Avatar
That's pretty much had in mind. start out the cheaper route then when and if this economy picks up and working more hours which means more money drop in something bigger.
Quick Reply: Hybrid 5.3L ????
