Will too stiff a valve spring wear out a lifter or other components prematurely?
I've got about 25-30K on my PRC dual springs. I don't have a big cam, just a Torquer 2, which is 232/234 .595/.598 on a 112. I'm thinking it is time to replace them just for peace of mind. I don't track the car, they are all street miles. Anyways, I have been looking at replacement springs, and was either considering the TSP EHT springs:
http://texas-speed.com/shop/item.asp...=1013&catid=48
Or the Livernois dual springs:
http://www.livernoismotorsports.com/...t.phtml?p=1665
Then I was thinking that these springs might be a bit much for my needs. Will a spring designed for a larger cam cause excessive wear or stress on other components?
you should be good, but try to stay within valve lift. .650 springs should be good enough... I have about 50k miles on my springs running a 231/237 .589/.595 112+4. dont plan to change anytime soon.... if yo do change springs then I recommend to change lifters...
Not sure on the TSP as they don't provide any stiffness values. However, the Livernois springs are pretty stout and with stock GM lifters you could have some issues. If the current springs are working for you and you got this many miles out of them problem free, why not just do a one for one swap? Also, PAC has some duals which are good springs, not sure on the stiffness though and you would need to check them.
LS1Tech Premium Sponsor
PRC .650" Lift Spring specs:
Closed Spring Pressure: 145lbs @ 1.800"
Open Spring Pressure: 450lbs @ 1.150"
Maximum Spring Lift: .650"
Coil Bind 1.080"
Spring Rate: 469lbs/in
PRC EHT .675" Lift Spring Specs:
Closed Spring Pressure: 157lbs @ 1.800"
Open Spring Pressure: 471lbs @ 1.125"
Maximum Spring Lift: .675"
Coil Bind 1.060"
Spring Rate: 483lbs/in
PRC .700" Lift Spring Specs:
Closed Spring Pressure: 160lbs @ 1.850"
Open Spring Pressure: 460lbs @ 1.150"
Maximum Spring Lift: .700"
Coil Bind 1.080"
Spring Rate: 429lbs/in
Coil Bind 1.080"
Coil Bind 1.060"
Coil Bind 1.080"
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
As far as the springs, we have even tested springs that came out of cars after as much as 60,000 miles with full bolt-on's and a large camshaft and they were still within spec.
Regards,
Rick LeBlanc
Livernois Motorsports
Thanks for the call, Paul. We'll have the spring and other item headed your way!
Matt
Matt
__________________
