dual springs not fitting correctly in 4.8 heads?
I just installed one of my dual valve springs that I purchased from a member on here and found that the seat wasn't going flush with the bottom of the head. The diameter of the seat is bigger than the stock ones... the spring went on alright and seems to be sitting ok now but I was just wondering if this could be a major problem
thanks
thanks
I agree, you need a valve seal thats seperate from the valve seat, dual springs wont fit over 1-piece seat/seals. I picked up a set of seals for a 00' silverado 6.0,From oreillys they fit fine. However youll need a set of valve seats to go with your springs.
