5.3 cr on piston?
Old 03-27-2011, 01:21 PM
gallo-lo's Avatar
Default 5.3 cr on piston?
im building a 5.3 for boost, im looking to use a 5.7 -3.892 bore 1.300 CH. What will be compression ratio on a set 317heads? im also looking into e85 as fuel.
Old 03-28-2011, 09:57 AM
LS1Tech Premium Sponsor
Sales2@Texas-speed's Avatar
Do you have a specific piston you're considering? A part number would be helpful so we can see all the specs and then help you with the compression calculations!
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
