cam help for 383
cam help for 383
I have an 04 silverado ex cab with ls 383 that makes 415 rwhp n/a engine mods are.forged rotating assem.with -2cc flat top.706 casting heads fully worked with comps duel springs.comp cams 219/227 .607/.614 lift.it also has ported stock intake and t.b and stock injectors.I need to know what cam will make me more power and what intake/t.b and injectors.I want to hit 500 plus rwhp.o and btw I have spray on it to.any help will be greatly appreciated
I have had two costom cams specced out by Geoff Skinner at Engine Power Systems, he has proprietary grinds and lobes on some of his setups A ton of guys run his cams, I have NEVER heard a complaint. Give him a call, 225-751-8500 Awesome guy to deal with, You wont regret it. If you are wanting great power as far as intakes, You will need a F.A.S.T intake setup. I have a ported 92 and his cam in my 383 in my sig.
RARON455, I'm considering a 383 build myself. I know when you go for power you sacrifice fuel mileage, but I'm curious how much. With your setup, what mileage do you see on average? Highway and city if you've observed both, and what did you get prior to your build? Thanks!
