Head Gasket question...
Is there a rule of thumb when getting the proper Head Gasket..as in you want so many thousandths over the Bore size and Head Chamber size?
I have a 4.030 Bore and was going to get that size Gasket, then I remembered the L92 Heads I have require a minimum 4.065 Gasket Bore so the Chambers aren't affected.
I'm trying to check everything when I put my Ported Heads back on, I want to make the most power I can doing it right.
