403 CID LS Owners?
403 CID LS Owners?
I see alot of kits offered in the 402,403,408 range for LQ4/9 and LS2.
Still thinking about LS engines especially Gen3's as the LS3 & LS7 stuff looks to $$$$$.
What do you guys have as far as cam,heads,rotating assemblys?
Anyone using professionally ported LS6 heads and anything but a FAST intake?
408 here
2002 6.0L cast iron truck block
Mahle -12cc forged dish pistons
Eagle 6.125 4340 forged H-beam rods
Eagle 4.000 4340 forged crank 24x reluctor
ARP Main Studs
Mahle rings
King bearings
Comp 251/261 .624/.624 115 lsa cam
Ported/ polished/ milled 241 heads
Edelbrock Pro-flo XT intake
FAST 90mm tb
Edge (motron) 60lb injectors
Pacesetter lts
Dual 3" exhaust
ARP Main Studs
Mahle rings
King bearings
FAST 90mm tb
Pacesetter lts
Dual 3" exhaust
What are you looking to put this in? I had to cut the hood on my 04 goat and from what I understand you have to cut the hood, cowl and maybe notch the windshield on anD-body to fit the Pro-flo intake
The most likely victims are '93-'02 Camaro or '84-'88 Monte Carlo SS.
