LS2 GTO Front sump pan dimensions?
I've tried searching, but I can't seem to find anything on the dimensions of the GTO front sump pan. I have a nice custom moroso front sump and I hear it's shallower, but I would like to know how much.
From the front lip to the bottom of the sump/pan. My moroso is 5.5" deep from the top of the lip to the bottom. Oh, and also from front to back of the sump too. Mine is 5.5 on the outer edge and 6.75 on the center.
Oh, Just realized I posted this in the internal section, not the external section sorry!
ffrom the block strait down to the bottom of the pan 6"s. from front of block to the back of the sump it 9 3/4" this is measuring the outside of the pan. I just happen to have my motor hanging over the engine bay getting ready to drop it on lol
Sounds like they are pretty close except for your lower front width, but looking down in the engine bay it should clear everything.... plus the aluminum pan is thicker so that might be the biggest difference in the height. The pickup is pretty small and centered on the sump surrounded by a bog sheetmetal astrik that is bolted to the bottom of the inside of the pan as a splash sheild
