Is anyone using a sheetmetal intake on a 346 with any success?
Is anyone using a sheetmetal intake on a 346 with any success? I was thinking out loud at work today, and we were wondering with the recent high hp H/C setups (490+ rwhp) would any of these benefit from a sheetmetal intake and bigger TB. I mean, the 90mm LSx intake/TB combo is pushing $1400, a sheetmetal intake/TB combo can be had for a couple hundred $$$ more than that, and would provide more room to grow, IMO.
So, on a 500 rwhp H/C motor with NOS, wouldn't a sheetmetal intake provide more gains/flexibility than the LSx combo?
Shawn
Shawn
Shawn
Shawn
The LSX is the way I would go, most sheetmetal intakes are $1500 to $2000 without the TB.
Just my 02cents
Adkoonerstrator
Originally Posted by Nick Agostino
which one? I didn't know GM had an aftermaket/performance intake for the Ls1
https://ls1tech.com/forums/showthread.php?t=120327]
Originally Posted by XLR8NSS
You could easily do a stock fuel injection (pcm) set up with that intake
Nice to see you again Nick.
There have been some locals here in houston that no gains with them, and they lost alot of low end. Not worth it IMO
How about a GMPP intake?
I think these are mostly made for putting a gen 3 in a older car with a carb.
Kurt
If any is seriously interested. Please PM as I can help you acquire one - NOW. I've been able to help several folks on the board acquire these over the last couple of months.
The GMPP intakes were made for a racing class. They can be used for older cars for sure as their is an adapter for running on the LS1 with a distrubtor. Of course a crank trigger can be used as well.
I have a point of contact for the new GMPP intake. It's like a carb intake for the LS1 BUT it is set up with injector bungs. It's possible to use it with fuel injection and speed density tune and I don't think using a MAF is beyond reason. Solid346 is the pioneer with w/4th Gen's and this intake. I think a new hood might be needed.
Looking forward to hearing about the results. This being a metal intake there is material for porting etc to get the best gains out of it. I think for best results one would want to port it as with any metal intake.
When we get my engine ready, I'm hoping to be able to do a little engine dyno testing with the GMPP intake on my new LS1 for the 3rd Gen. Should be able to test several ported intakes.
LS1Tech Co-Founder
I've been witness to and have facilitated the testing of several intakes and most of them lost horsepower and torque below 6000 rpms.
Only one intake that was tested showed a small gain of peak horsepower and torque. An earlier version of this particular intake did not do well, but once it was revised it made as much power and torque as an LS6 intake from 5000 to 6000 but made another 10-15rwhp over an LS6 intake. I don't think this intake will go into commercial production anytime soon.
And Shawn, if you did a sheetmtetal intake like a Beck's you are looking at $2000 + a throttle body so you need to in the cost of the throttle body or just compare the intakes, so $850 for the 90mm FAST vs $2000 for a Beck sheetmetal which is what SAM has used.
