Oil on 4 spark plug threads
Old 03-29-2011, 07:21 PM
209SlowLS1's Avatar
Default Oil on 4 spark plug threads
Whats up guys I was just wondering if anyone had some tips for me before I started pulling her apart. The only plugs with oil on the threads (not on electrode) is 3,4 and 7,8. My car isnt using oil and my mods are LS6 mani, slp lid/bellow, kooks LTS + some. Should I start by checking the mani to see if the pcv has oil in it? I was going to do a comp. test today but unfortunately I need a different spark plug connector =(.. Any advice would be appreciated.
Old 03-30-2011, 01:04 AM
209SlowLS1's Avatar
Update: I did find a good amount of oil in the intake manifold ill continue with my investigation tomorrow. Another side note is it runs flawlessly =)
Old 04-07-2011, 02:08 AM
Abuckeye's Avatar
Oil in the intake runner walls is usual. You could've had blow by on the piston rings and the oil squeezed out to the plugs. Was it thin runny oil or caked on thick oil
Old 04-07-2011, 11:56 PM
209SlowLS1's Avatar
Thin runny nothing caked, the oil in the mani was runny as well
Old 04-08-2011, 10:28 AM
O2Form's Avatar
Typical Ls1...ferget about it.
Old 04-13-2011, 02:27 PM
209SlowLS1's Avatar
Sounds good to me..
Old 04-13-2011, 02:35 PM
6speedt/a's Avatar
Have you ever had the plugs out before? It could be anti-sieze
Old 04-13-2011, 09:34 PM
209SlowLS1's Avatar
Negative.. Why would it only be on 4 plugs that are across from eachother?
Old 04-13-2011, 09:38 PM
209SlowLS1's Avatar
BTW thanks for the info guys it is appreciated. I hella wanna cam this thing so I need to do a compression test on this bad boy to make sure, I just have to make some time. I know with the srt it was usaully from the valve cover tube seals but thats apple to oranges, and I never had this problem with my LT1..
Quick Reply: Oil on 4 spark plug threads
