Where is the milling -vs- compression chart at?
Old 02-18-2004, 05:11 PM
SPANKY LS1's Avatar
Default Where is the milling -vs- compression chart at?
Where is the milling -vs- compression chart at? There used to be a chart here that explained how much compression a certain head (5.7, 5.3, etc) would have when milled a certain amount (based on combustion chamber volume), and I can't find it, So, what compression will a 5.3 head have when milled:
.010? .020? .030? .040? .050? (assuming a stock gasket). What about at different amount of chamber volumes?
Thanks, Shawn
Old 02-18-2004, 08:17 PM
DaleMX's Avatar
Right here.
Dale
https://ls1tech.com/forums/advanced-engineering-tech/111207-ls1-head-combustion-chamber-cc-volume-vs-cr.html
