lq4 with ls2 timing set, in ls1 car
im not sure where to post this and i dont know without asking, search wasnt much help for this specific question.
i bought a lq4 block.
i bought a custom cam, it has some kind of thing on the back, like two half moons ? i assume this is the cam reluctor wheel for an ls1?
i have an ls2 timing set, but stock lq4 cover.
what cam sensor setup can i use? this will be going in a trans am. so whatever works with stock 99+ pcm would be fantastic.
do i need to buy a new ls2 cover / sensor or can i use an ls1 sensor in the lq4 block or do i need an lq4 specific sensor for the lq4 block that will work with the ls1 reluctor wheel?
my heads going to explode!
LS1TECH & Trucks Sponsor
What year is the motor you are dealing with? If it is a gen 3 style iron block then you can run an LS1 style timing cover. If it is a gen 4 block then you will need the ls2 timing cover and the harness to extend the stock cam sensor harness to the front of the motor.
