Got eps cam card today! Need help
Old 04-01-2011, 08:33 PM
theevette's Avatar
Default Got eps cam card today! Need help
I got my eps cam today is a
Lift 600 In 603 Ex
Duration 230 In 238 Ex
Lobe sep is 112 with 3 degree built in
Centerline is 109
I have been have terrible issues with spring selection. I did some homework and my ls6 hollow valves weigh aroung 77g and my stock springs weigh
around 75 g plus 11 g for the stock retainer. It seems to be around 40g less then the ls1. A pac beehive weighs 75 grams and 5.7 grams for a titanium given a total of around 158g complete. If I run pac 1521 or any other dual for that matter they weigh 102 g for spring and 10.3 g for the titanium retainer giving me around 189 g total weight. This is all without locks which run around 2-3 grams. My oe ls6 set up is around 164 grams. These are all rough numbers but should be in the balpark. I use my car for raising hell daily but do alot of long road trips.
It looks to me with this cam size pac 1518 beehive should be real durable for my set up or am i wrong and should opp for the duals and give up the 30 or so grams of weight. I just dont know what to do. My lift looks more then safe but does duration and seperation have anything to do with my selection. Is 130 to 140 seat preassure good for me. It should peek around 6800 is what I been told and should run a 7.425 push rod and leave the oe locks. What should I do.
Thanks Clint
Old 04-01-2011, 08:57 PM
*02WS6TURK*'s Avatar
I'm running the Pac 1518's. They should work just fine for that cam.
Old 04-01-2011, 09:49 PM
Old School Heavy
speedtigger's Avatar
Lift 600 In 603 Ex
Centerline is 119
119 degree intake centerline? Are you sure that isn't 109 degrees?
Old 04-01-2011, 10:24 PM
garygnu's Avatar
another use for a pot scale.
Old 04-01-2011, 10:28 PM
disc0monkey's Avatar
1518s work fine with eps lobes
Old 04-01-2011, 10:42 PM
theevette's Avatar
it is 109 centerline typo sorry
Old 04-01-2011, 11:56 PM
A.R. Shale Targa's Avatar
LMFAO...........ur2funny sir
Old 04-02-2011, 07:06 AM
wytry's Avatar
Not gonna lie, this definitely was my thought before I even saw your post
Old 04-02-2011, 12:30 PM
_GTO_'s Avatar
Why 's the big split between int/exh dur ?
Are u going to spray or what ?
Old 04-02-2011, 01:07 PM
theevette's Avatar
I had a cam spec done for my setup. No spray. Trying to get as close to 10s as possible with stock heads. Guys these weights were gathered from another thread I believe ferrea put up years ago. There is a reason people use ti vavle and gm used the sodium filled. It was to save a few grams and allow the valvetrain to be more stable at higher rpm. It is another pot scale use which is funny by the way
Old 04-02-2011, 01:35 PM
mattster03's Avatar
Good cam ... seems like geoff tends to suggest it for light cars. I bought the same one, 230/238 though mine has a 110 ICL.
Old 04-02-2011, 03:26 PM
theevette's Avatar
Which springs you go with and why the 110 and not the 112?
Old 04-03-2011, 05:17 PM
mattster03's Avatar
I am running the dual springs that came w/the TSP heads. I did get the 112LSA cam, but it has 2* of advance ground in for an ICL of 110
Old 04-03-2011, 05:56 PM
xpndbl3's Avatar
I'd run dual springs just because in the event of failure you won't have a valve drop, piece of mind is well worth the cost. Running the patriot gold extremes on a EPS cam.
Old 04-06-2011, 09:35 PM
Thought there was a mention recently that some vendors are on back order
for the Patriot gold duals ????? TSP duals or Lunati makes a complete kit
gold duals, retainers,seals,locks.....$225
Old 04-06-2011, 09:53 PM
itsslow98's Avatar
Geoff advised me against patriot golds because even though they are titanium the size of them still makes them heavier then most other titanium retainers. I wound up buying Pacs for my 234/246 cam from him. He recommended the 230/238 the OP got but i wanted bigger and he said since my coupe will be so light(2700lbs) the bigger cam will be great.
Old 04-06-2011, 10:57 PM
theevette's Avatar
Did you get the PAC singles or duals
Old 04-07-2011, 12:15 AM
MattSapp95_T/A's Avatar
Why not just ask Geoff what he recommends?
He actually steered me away from the Beehive springs...
I just told him to bill me and ship me whatever springs he thought would work best...
Matt
Old 04-07-2011, 12:19 AM
itsslow98's Avatar
Duals due to the size of the cam. It was like 835 for the cam, springs, and pushrods shipped.
Old 04-07-2011, 09:52 AM
mattster03's Avatar
seems like 90% of the cams geoff is specifying have a big split. some of his more popular choices so far:
220/226
226/234
230/238
236/246
they do make great nitrous cams, which is my intention... but i think there's more theory behind the splits
Quick Reply: Got eps cam card today! Need help
