Best heads,bang for buck,347ci
What are the best heads for a mostly street 347 ls1.Looking for bang for the buck heads,not ultimate hp heads.One of the various ported heads like tex. speed,etc.?Or should I hold out for aftermarket heads like trickflows.I have a good set of stock 241s I can get ported if thats the best route.Opinions,suggestons,advice welcomed.
There have been a few threads on here recently of poeple who are very
pleased with the results from sending their 241s to Advanced Induction.
Check in the dyno results section I think Damian did the build and tune.
Pretty sure he CNCs the runners from 204 to 219cc, valve job (stock valves)
New PSI maxlife bee-hive springs (good to .625lift), seals, and mill to comb.
chamber of desired volume. I know the 243 castings are a better starting
point but since you already have those I'd click on the AI link to the right
and give the guy a call. I wanna say Phil is his name
On another note, I went with TSP Stage 1 LS6's over the 5.3's. They will mill them for free to your desired specs if you want a compression bump. I went with 62cc chambers for my Torquer v2, and will be going down to 60cc's after I flycut and change cams. But yes, I believe they are an excellent bang for the buck head.
Well,I have an l92 that I will do later on but for now it will be an ls1,stock bottom end,(fresh)with a good street cam and ported or aftermarket heads.With stock pistons I cant get too wild on the cam so probably 230ish,113-114,600lift or a little less.Ls6 intake,headers.Its going in a 66 chevyII with a six speed,355 or 373 gears.Aftermarket front clip so guessing around 26-2700 lbs.Just dont want to leave too much on the table not doing the aftermarket heads but not sure it worth the extra money or not.Ocasional blast on test and tune night but mostly a fun street car. Suggestions welcome.
check these heads out from Livernois Motorsports. Remember to always keep your options open .
http://www.livernoismotorsports.com/...t.phtml?p=1351
If your on a budget have AI work your 241's like mentioned. I bet they put out better numbers than patriot's stage 2 243's lol...
http://www.advancedinduction.com/AiProductsGMLS1.html
http://www.advancedinduction.com/AiProductsGMLS2.html
TF heads/cam package as cast 220's with rockers = $2900
TSP 2.5 LS6 heads/cam package = $2140.
(both are priced with all gaskets needed)
A budget head compared to a premium will be about a 15-20 hp difference on average. But your paying an extra 1k for that.
I don't wanna sound like I'm swinging from anyons nuts, I've just been doing A LOT of research trying to find the best bang for the buck.
You could get the 2.5 LS6 heads milled to 11:1 compression and they would be about the same as the TF as cast 220's. Plus with the TF they recommend rockers which are over $400.
Ummm I paid $1700 for my heads and have seen them at VR with free milling for $1600. You can pay $100 more and get the harder powdered metal guides like GM uses and not need the rockers... I would still shim .090 to improve geometry so a little more for the shims... You also get a thicker deck and stronger rocker bosses to boot...
EDIT: $1700 for heads with TEA Gold springs, + $425 for custom cam...
Didn't know you don't have to use the rockers. What are the downsides to not using them? The price I got was right off VR website, but didn't see anything about 86'ing the rockers. Both shops will mill for free.
-so for TF setup 220 as cast with H/C and no rockers = $2225.00
-TSP 2.5 ls6 H/C $1979.00
-or go with the TSP stage 1 LS6 for $1569.00 and sacrifice ~5hp, but the valves aren't as good.
So all things being equal you'd probably have about the same HP with the first two setups and the TSP's being $245.00 cheaper but with TF arguably having a better head. Tough call, guess it depends on just how much of a budget your on. Both are a tried and true head so for me personally I'd probably save the $245 and use it on a new oil pump and timimg chain.
