Finally going to get a cam, advice please!
Hey guys my car and mods are in sig. I know zero about cams even though i've searched and searched and tried reading all I can. I plan on having a cam only. If i do heads it will be a long time from now. I want to get the best bang i can out of this cam. My question is without having a stall and with the mods in my sig, whats the biggest cam i can get that will provide the most gains? Sponsors please let me know also if you can hook me up with a custom cam package or whatever i will need. Thanks
Congratulations on what should prove to be a great decision on your part!
Can you give us a little flavor for your driveability requirements. Is the car a weekend warrior that spends a good bit of time at the track or is it a daily driver that needs to be reliable on the streets?
The simple scoop is that (as a general rule) smaller cams will net you good power under the curve and can easily be tuned to provide good street manners. By contrast, larger cams will net you more power up top and usually give great peak numbers but the trade off is they're a bit more tricky to tune and might be more than a handful for a daily driver automatic without a stall.
Personally, I went with a middle of the road option. Trick Flow 228/230 .585/.585 @ 112 LSA. My goals were (in order of priority): 1. reliability as a daily driver 2. Power throughout the curve -- I would sacrafice a few hp on the peak side to keep it strong under the curve. 3. A noticeable lope. The cam I chose does an excellent job at meeting those three criteria. If I had it to do over again, I would've considered a VRX3 or VRX4 from Vengeance since I added heads and a ported FAST to the mix -- however I have nothing but good things to say about the Trick Flow cam.
sorry to double post but i would also like to know if me and a friend can install the cam and all supporting parts in a day or two with basic tools? I"m not very mechanically minded at all my friend is pretty good however. But how hard is the install? I don't have the cash to pay someone 800 bucks to do it lol
i would suggest a 224 or 228 cam from tsp. your gonna want a stall however. i would personally get a stall first, you'll be much happier.
it can take a day to do if you know what your doing.
you need to get it tuned though once its installed
stall.
if you chose the 224r i can personally tell you that it's a perfect dd cam. 114 lsa is very well mannered. and with the a/c on it sounds like a stock cam haha
lol yea i hear ya man. Thats not exactly what I want though. I want that badass thump at an idle. Like I said before I really don't have the cash for a stall or the knowhow to put it in, i'm just looking for a cam right now.
If you want to break 400 whp then I would highly recommend contacting Patrick G or Predator Z for custom cam specs...$25 well spent.
https://ls1tech.com/forums/generatio...am-change.html
My personal thought...don't go over 224-ish duration or wider than 112 lsa (unstalled), for the powerband and lope you need/want. A stall makes a big difference!! I hope you plan on getting a tune??
1) get a stall first, especially if you want a big gain, which would mean medium to large cam.
2) the cam swap can be done in 4 hours, including springs. so research it, take your time. allow a full weekend just in case.
3) allow money for a tune afterwards, especially if you want a cam with a nasty idle.
yeah you're not gonna be able to hit 400 rwhp cam only w/o a stall. and you damn sure aint gonna do it w/o a tune.
stop trying to cut corners and listen to what we are saying.
I did both at the same time. Im at 379hp with my 233/239 cam and 3600 stall.. Driving wise, I don't know say since after I had it dyno tuned and took it out on the street for the first time the trans broke shifting into 3rd.. I think you're going to need a 228 cam at least and a stall to hit 400+hp.
