Think my motor is f#@!$&??
Old 04-10-2011, 07:04 PM
ISMELLRICE's Avatar
Default Think my motor is f#@!$&??
http://www.youtube.com/watch?v=bdfQn...e_gdata_player
Hey guys I bought a 98 z28 yesterday long story short I bought it for 500 bc it wouldnt start...it was parked for well over a year (it was my uncles neighbor)...
Had it towed home and cranked it up with my trans am battery...this is the noise I hear lol...
Now I drained the oil the thing had about 8-9qts of oil! Not good but not shiny but the drain bolt tip did have a bit of metal shavings..
Any opinions?
Thanks
Old 04-10-2011, 07:13 PM
remauto1187's Avatar
You have a Rod(s) knocking. Bad rod bearing....but you still got a great deal for the $$.
But to be on the safe side i would check the other possibilities that mimich the sound of a rod knocking. Valvetrain loose (rocker arm), bent pushrod, etc. also check exhaust manifold gaskets for leaks and loose torque converter bolts.
But it sure sounds like a rod hammering like a SOB to me. Hear the rat tat tat as you rev up a little and then let it coast back down. Typical noise of a rod knocking.
I wouldnt start it up anymore to minimize any further engine damage and start pulling the engine (after check the other possibilities out).
Pull the oil pan and id bet you will find metal pieces in there. While pan is off, reach and grab the rods and try to wiggle them back and forth (driver to passenger side of engine). The ones(s) that really wiggle are the culprits. Complete engine rebuilt will be in order. There will be metal pieces all over that engine (internally).
Old 04-10-2011, 07:55 PM
devlmaycry's Avatar
Ouch, good deal, but that sounds rough. Maybe those 8qts of oil kept the noise down while he ran it into the ground. Was it like peanut butter when you drained it straight 90w lol. $500 is still a good deal. You can get a used LQ9/LQ4 for cheap and drop it in!
Old 04-10-2011, 07:59 PM
ISMELLRICE's Avatar
I already took the drivers valve cover off nothing too crazy for 100k miles...tomorrow I'll check the passengers side...might eden take off the head the heads off to take a better look
Old 04-10-2011, 08:21 PM
Mean87SS's Avatar
Can't even get a roller for that much.... you did well.
Old 04-10-2011, 08:31 PM
midevil1's Avatar
Is it an A4? If so, check the flexplate. Could be loose. Sounds just like a rod and the harmonics will travel thru crank. Great deal no matter what it is though..
Old 04-10-2011, 09:53 PM
trans_am7935's Avatar
check all your spark plugs and make sure one of them didn't back them selves out. this happened to me and it sounded just like this. so check those
Old 04-10-2011, 10:26 PM
ISMELLRICE's Avatar
Damn you know thats one easy thing I didn't check...ugh I'll get to those tom.
Other details on the car it's original owner all the way from 98, everything inside works..already had an offer of 200 for the body kit that these cars came worth so total price of the car could be less than 500 lol
This is it^^
Old 04-10-2011, 10:39 PM
Macs98Z's Avatar
I agree with it sounding like a rod knock, but did anyone else notice what looked like exhaust smoke coming up from the drivers side manifold around the 31 second mark in the video? Might be somethin to check out as someone earlier mentioned it could be a severe exhaust leak causing the noise. My guess is still a rod, though...
Dang! 500 bucks is a steal, and it looks like the paint isn't too bad either. Nice find!
Yep you did good! Hell I'll take 3 of them!
Drop that oil pan! It will tell all!
Old 04-10-2011, 10:43 PM
IRONFIST's Avatar
That's rod knock....
You need a new engine.
Old 04-10-2011, 10:47 PM
ANTICOP RAM AIR's Avatar
I'm willing to bet you have a spun main bearing, He got that bitch hot and spun a bearing Im sure. Hows the oil pressure? Either way, you could easily part it out and triple your money. OR 6.0 time baby...
Edit:
Put some 80/90 in it and sell that bitch.. lol
ShortChevy's Avatar
Buddy of mine had the A/C comp, clutch go bad and it sounded like a badass rod knock. Quick easy check to pull the belts. Start it up for a couple seconds and that will eliminate all the the accessorys.
Old 04-10-2011, 10:51 PM
scj
scj's Avatar
the dash pad's gone too man.
Old 04-11-2011, 01:21 AM
Edit:
Main Bearing noise is ALOT deeper in tone. More of a growl noise than RAT TAT TAT like a rod knocking.
Old 04-11-2011, 07:32 AM
ISMELLRICE's Avatar
good eye on the smoke...i saw that also after i had turned it off...i should of checked the spark plugs first but my newbness stopped me from checking something simple like that since my first reaction was holy **** thats really loud must be valvetrain lol...
the paint is pretty shitty on the sail panel and on the rear bumper...no worries though if i get this thing running for cheap it will be my 2nd f-body and more than likely the one i beat on weekends...
going to start looking at my options on this pretty soon since i work at a school we get 2 months off during the summer which i could use to work on this as a project as im still getting paid my regular pay without driving to work...
i hope its something simple in the heads and all i have to do is order some 5.3 heads from texas speed and go with a pretty nice came and call it a $2000 13 sec car lol
Old 04-11-2011, 08:06 AM
Thats what mine was. It was the exact same sound. Either way, his motor is fucked tho.
Old 04-11-2011, 08:26 AM
I just found a 98 ls1 longblock for sale.. $1000 and can verify condition/running its in D/FW area though. Wouldnt be a bad deal, a running LS1 car for under 2K.
Old 04-11-2011, 09:40 AM
rncotton's Avatar
My car sounded just like that. Before taking the plunge, I checked everything I could. Clutch / flexplate, exhaust manifolds, spark plugs, harmonic balancer, then pulled the heads and checked the lifters.
Then I had no choice but to pull the motor and it was what I expected it was. Spun main bearing.
http://www.rogercotton.com/misc/bearing.jpg This is less than 4000 miles after letting a local shop do a rebuild.
Old 04-11-2011, 09:58 AM
ISMELLRICE's Avatar
hmmmm 6.0 search? lol
