Do I need different heads for ATI blower?
Old 02-19-2004, 09:03 PM
IRVINEWS6's Avatar
Default Do I need different heads for ATI blower?
I currently have MTI stage II heads, milled .030". I just ordered an ATI supercharger, and I want to lower my compression. Will changing the gaskets, pistons, rods, bearing, etc. be enough? Or, do I have to buy new heads?
Old 02-20-2004, 10:31 AM
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,099 Likes on 721 Posts
You're at 10.4:1 - 10.5:1 now with the milling.
You can get by with that compression, but when you tune the car you might dialing back the timing a bit more than if you had stock 10.1:1 compression.
In an ideal world you would someday get some 70cc 6.0 heads and drop the compression down to 9.8:1 or less.
Old 02-20-2004, 12:15 PM
IRVINEWS6's Avatar
If I want run more boost, say 10psi, will new pistons and gaskets be enough, or do I need to buy 6.0 heads?
Thanks
Old 02-20-2004, 12:19 PM
JoSeY's Avatar
The 6.0L heads, good tune, and YOU MUST HAVE AN INTERCOOLER....to try 10psi w/out an intercooler ur just a time bomb waiting to happen...bad batch of gas...ur buying a new shortblock. U could sell ur MTI heads for a set of ported 6.0L heads...just make sure they haven't been milled.
Old 02-20-2004, 12:22 PM
IRVINEWS6's Avatar
I thought the ATI chargers have an intercooler...?
Old 02-20-2004, 12:33 PM
LS1Tech Co-Founder
I can move this thread into FI if you want, you would get a lot more replies.
Old 02-20-2004, 12:41 PM
JoSeY's Avatar
I know buying them brand new from ATI u can get the 3core or the twin coolers...but he never mentioned who he was getting the blower from or if it was coming w/an intercooler....he just said ATI....in this game I don't take anything for granted anymore....I try and double check everything.
