cant figure this out P0300/random misfire
tends to happen alot when its cold out in the morning, but once warmed up its fine, so far i put new ac delco plugs iridium in gap to 0.40, new 02 sensor since it threw the code, i tested the coil packs with an ohmmeter tester, they were all the same, im thinking one coil pack is slowly failing but cant figure out which one it is
98 z28 camaro 6speed trans, mods are comp cam (dont know the specs, came with the car), intake, straight exhaust with no muffler (will be fixed soon)
probably a stupid question but where are most of the vacuum lines located, and on the far back on the drives side, theres something blocked off on the valve cover with a rubber boot but it dry rotted and broke
and also could a egr delete cause a misfire? they took it off the car
The vacuum lines (PCV) run from both valve covers to the front of the motor and then go to the intake manifold and throttle body. That rubber boot you are talking about on the driver's side is part of it, and if it's cracked and dry-rotted, then it's almost surely leaking there.
What kind of PCV do you have in place now? You can replace those PCV lines with fuel line if you need to...
i found one line on the passager side, it needs to be replaced, i tried finding where the other hose went from the drivers side but couldnt find it, can anyone post a pic on the drivers side of where it should be hooked up to.
and as for the tune, i have NO idea if it even has a tune, i cant even turn my a.c on somtimes cuz it'll stall out my car, so i messaged someone on a site called tamparacing.com who does tuning and a dyno so im gonna see how much its gonna cost me, i found one place thats $400 for a tune
If its a reputable shop go with that. Thats about the going rate. id say thats your problem for sure if its stalling with the ac on. the pcv sysem hose for the drivers side is at the rear of the motor on the valve cover. Imagine if you took the passenger side off flipped it around and put it on the other side. rear facing at the back
the whole pcv is pretty much blocked off -.- caps on both side of the valve covers the pcv line was bent around and looped under where it comes out near the intake, gonna go to chevy today after school and find out how much this will cause since im sure i wont be able to get it from adv.
I just rebuilt my motor and put it back in. My P0300 code was caused by a Loose Spark Plug wire on #1 and a cracked Vacumn line to the rear hookup on the pass valve cover.
Took care of both issues and the problem has not returned yet
