Installed the Harland Sharp Rockers.
Nothing is for certain, right. The rockers on the drivers side did touch the valve cover. At 10 pm it wasn't fun to hear and they did clack pretty loud. They touched the baffle so slightly that there were no marks. Used the old trusty hammer to flatten the baffle some, clayed the rockers and buttoned it up and now I'm happy again. Other than that they install easily with no other issues. They are quieter than stockers and since I went up in cam size at the same time that also is nice
They are pretty. It's a shame to have to hide them.
Originally Posted by 98blackSS
No doubt.. Mine seem to be doing well too.. I didn't have any issues with them touching the valve covers, but they were extremely close to the head wall on each end.
I should add that I installed a cam at the same time. It's a 228/588. But the rocker did not touch on the pushrod side.
In my case the only rocker close to the wall is number one at the top. Eyeballing looks like between a 1/16 and 1/32 inch. It seems that there will be no big install issues for most. But the head castings do vary for sure.
Originally Posted by JF WS6
Where did you guys buy these? Did you get them from Nate in the GP section? I'm going to need to get a set of these........
Originally Posted by jimmy 2 Times
ordered mine last week, i cant wait to install
Here's my tip of the day. When the install is complete and you're ready for the valve covers, keep the coil packs disconnected, bolt down the valve covers and turn the engine over. If you have clay use some. This way if anything touches you will not have to remove everything. Mine is probably a little unique, but why not check?
Enjoy them.
