LS6 cam in a 5.3 - what pushrods??
With the 2001 LS6 cam the difference in the base circle between the stock 5.3L cam and the LS6 cam is .032" so 1/2 that amount is the difference in the preload . So You'll have .016" less preload which should work just fine . If You go to a 7.425" p-rod You would end up with roughly .009" more pre-load which also would work just fine . Good luck
