total degrees & rev limiter setting
Old 04-22-2011, 09:53 PM
hotrodsgmoney's Avatar
Default total degrees & rev limiter setting
what would the total degrees of ignition be on a 99 LS1 w/automatic.Also what is the rev limiter set at from the factorythanks hotrodsgmoney
Old 04-22-2011, 11:04 PM
mark21742's Avatar
if you are looking for the highest advance in timing, it would be about 42 degrees, if your talking wide open throttle, it would be around 25-27
i think the shift points were set right around 6,100 rpms
Old 04-22-2011, 11:08 PM
hiltsy855's Avatar
My factory rev limiter was set at 6200.
