Help cam & heads installed now knockin bad
I just installed a tsp228 cam, weiand manifold, and 243 heads on my 98 camaro and knw its knockin really bad like something in the manifold i took the manifold off and nothing was in it the car starts but seems like cyclinder 4 n 2 is dead any help ne one
LS1Tech Premium Sponsor
Check your valvetrain, preloaded issues can cause some crazy noises!!!
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Jason
2005 Twin Turbo C6
I just did a head/cam swap too from TSP with new pushrods and lifters and have the same issue. I tried longer pushrods and that seemed to help but still have loud valve-train noise. Using CompCams pushrod length checker, I get 7.375 and thats what I put back in it. I've tracked down the noise to the passenger side. Did the redneck screwdriver to the ear trick to find which cylinder and noticed the clicking sounds from cylinder #6. Inspected the rockers/pushrods and everything is snug and looking good - both intake and exhaust open and close correctly. I'm thinking a bad lifter but want to test this so I put back in the longer pushrods for just that cylinder to try and compensate for a bad lifter and low and behold the sound almost goes away. So I'm still thinking a bad lifter or two. Anyone have any other thoughts? I am going to call TSP in the morning and see about getting some replacement lifters.
'06 Silverado CCSB 5.3L
PRC Stage 2.5 5.3 Heads
TSP Torquer v2
CompCams High Energy lifters / TSP pushrods
Stock rockers
TSP Torquer v2
Stock rockers
Last edited by ErkDog; 04-25-2011 at 10:32 PM. Reason: those were stock rockers not stock lifters - doh!
I have done a few SBC builds in my youth but this was my first LS engine so I was very meticulous in doing this by the numbers - double checked everything.
I am excited to get all these issues wrapped up so I can take her out and run the hell out of her! So any advice is greatly appreciated 8-)
I'm pretty sure I did it the right way (put it back the way it was taken off) but just thinking out loud here - because if doing that offset the geometry then would that cause excessive vale train noise?
Here's something though: I noticed that the passenger side rocker stand was upside down (GM logo was upside down) and the drivers side was right side up. What would happen if I got that mixed up - put the passenger side right side up and the drivers side upside down?
What brand/type of lifter?
What brand/length pushrod?
I replaced mine with compcams OE High Energy hyd. lifters and TSP 7.375 pushrods. Even after rechecking the length with compcams pushrod length checker (still at 7.375) I still get excessive valve train noise.
My calculation was...
10.33 turns for zero lash * .05 per turn + 6.8 for the pushrod checker base length + .05 preload = 7.3665 rounded to the nearest .025 came out to 7.375
So the "actual" preload would be .0585 with the standard lengths of pushrods available (.025 increments).
Last edited by ErkDog; 04-25-2011 at 10:26 PM. Reason: added the exact calculation I used
(edit) Found the thread.
https://ls1tech.com/forums/generatio...-pictures.html
Here's an interesting thread with a LOT of info. I wish they'd sticky this.
https://ls1tech.com/forums/generatio...r-preload.html
YES... there was a guy Mike94ZLT1 or something. He had a C5 and was re-assembling the engine and forgot those. Dropped a valve or something and it completely destroyed his engine within minutes. NOT good..
But anyway. If it's coming from #7, it's the oil pump pick up tube o-ring. if it's anything other than #7 (the whole valve train) It's prolly pushrods.
My entire valve-train makes a lot of racket (heavy sewing machine noise?) but the klank klank klank comes from the passenger side (proly #6).
I'd already ordered new lifters/gaskets/bolts for that side. If this doesn't resolve the klanking then I will try the o-ring thing. And if that works I'll buy you a six-pack of Keystone Light!
