how far does crank pulley sit on crank
Ok, I'm finishing my cam swap and I got my pulley on but how far ? The crank an pulley line up flush on the front where bolt threads in?
How did you get it flush? Mine is at least 1/8" from being flush. I took a metal ruler that was 1" wide and laid it on the pulley up to the steering pulley to makesure that the belt was going to track straight. Check it put.
1/8" = 0.125", so if you're not more than 0.051" past 1/8" (i.e. not more than 0.176") then you're in spec.
Ahh, for some reason those images didn't load when I initially looked at the page... weird. I hope that step of transferring over the weights isn't required. I thought that was limited to Corvettes or manual trans cars or something like that.
I got the old bolt up to about 235 lbs and it was dead on at 1/8"!
