Stock rocker trunion upgrade
I am getting ready to change the valvel springs and cam. While I was in there I was wondering if you guys thought the trunion upgrade to the stock rockers was worth it or not.
If it is a good idea to do, what is involved to put them in the rockers.
Are there any advantages other than the stock needles going all over the place if there was a failure. Do they contribut to any better valvetrain control?
I just did it and would recomend it to anyone doing a cam. I'll spend a couple hundred to save a couple thousand any day. Slowly fixing GMs deficiencys one at a time. Next is the clutch master, then the rear end, then the...
I did mine back when my heads were put on last summer after finding like 32 needle bearings stuck to my oil drain plug! Best upgrade for the money and you might as well do it and be done and not have to worry about things. I got lucky cause those little bastards can cause lots of damage!
