Cracked ringland?
Cracked ringland?
I've got a missfire in the number 7 cylinder. Compression is only around 90 psi vs 190+ in the others. My first thought is a cracked ringland, but the car does not smoke at all. Just a little rough at idle. It is FI so I know this is a typical breaking point. Can I have a cracked ringland with compression that low but no smoking? I'm hoping it's just an issue in the valvetrain.
I had the somewhat common #7 piston come apart on me last year (portion of the top ringland coming apart). I drove the car home 30 miles from the track with alot of misfiring, but no smoke whatsoever. When i finally took it apart, a 1/4 of the top of the piston was gone, i could actually see the top ring.
Also had a friend break the ringlands on #8 with very minimal smoking.
