LG motorsport LS6 heads
Old 02-21-2004, 11:30 PM
WARNING! Bad Seller Alert
SSC5R's Avatar
Question LG motorsport LS6 heads
I have set of stage 2 ls6 heads that I got from a friend. Does anybody know what they flow?
Old 02-22-2004, 12:53 AM
JZ'sTA's Avatar
They are probally the same as AS stage 2 heads.
LG motorsports uses AS for their heads.
Old 02-22-2004, 12:15 PM
Glenn98ZM6's Avatar
LG only started using AS heads in the last 6 months or so. they also use another source for the top of the line heads if thats what you are looking for or are willing to spend and wait on them..
Old 02-22-2004, 01:38 PM
mike m's Avatar
is there a # stamped on the heads?
Old 02-22-2004, 02:37 PM
99 Black Bird T/A's Avatar
Received 1,431 Likes on 991 Posts
I would have them flow tested and not go by what someone else said. Also flow them with the LS6 or LSX intake that will help give a better picture of what they will do.
Old 02-22-2004, 02:46 PM
SSC5R's Avatar
There is a letter A ingraved in one of the intake ports.
Old 02-22-2004, 03:05 PM
My S1 JPR LS6's had the A ingraved in one of the ports too. I'm not sure why it was there I assumed it was from the factory and JPR didn't remove enough material to wipe it out.
Old 02-22-2004, 07:51 PM
GueSS Who's Avatar
Yes this is correct
Old 02-22-2004, 08:25 PM
SSC5R's Avatar
I 'll flow them at school then. We'll see if those # are what they are claimed to be.
Old 02-22-2004, 08:40 PM
bigeller's Avatar
So what is the significance of the "A" in the intake port? My SDPC CNC #243 casting LS6 had a "B" in the intake port.. ???
Old 02-22-2004, 11:35 PM
BurnOut's Avatar
With a good (fresh) valve job, I think the LG (not AS) LS6 heads are supposed to flow in the 315-ish range at .600, though I am not certain.
Old 02-24-2004, 01:14 AM
SSC5R's Avatar
Here is what they flow
Lift CFM
200 115
300 174
400 230
500 276
550 283
600 300
650 307
At 700 they backed off, I do have to say; they could have done a way better job on those heads. I'm not going to get into it now, but man what the.......
Old 02-24-2004, 11:10 AM
KGSloan's Avatar
those flow numbers seem pretty good. should make some good power.
Old 02-24-2004, 11:50 AM
kumar75150's Avatar
Uhhh if these are used heads, those numbers are not bad at all.
Old 02-24-2004, 12:04 PM
BurnOut's Avatar
Exactly. That's why I specified a fresh valve job... there can easily be 10-15 cfm lost because of poor flow characteristics around the seat... and, by nature, valve jobs go away over time (that whole "valve slamming shut" thing and all). Depending on how used those heads are, they may just need some freshening up.
All in all, though, 300 at .600 isn't exactly horrid.
Old 02-24-2004, 02:21 PM
SSC5R's Avatar
They need a new valve job, valve guides and some muching due to the guides having small cracks around the guides when they were inserted. They still have some ruff spotes in the ports that need some work.
Quick Reply: LG motorsport LS6 heads
