Anybody have the specs on lm7 and lq4/9 heads?
Anybody know the specs one the stock 5.3 and 6.0 heads? Like intake and exhaust runner volumes, combustion chamber sizes, and flow numbers.
Hello , how's it going ? All Ya gotta do is Google "GM # 12561706 or 12561862" or "1999-2004 chevy 5.3L cyl heads specs" . I'd rather teach You how to fish than ...... Good luck Any questions other than basic specs or if You can't find something ........ask by all means . Oh Ya , did You see the sticky at the top of this section , it's also got all that info , thanx
I know the 317s lower the compression and flow comparable to the z06 heads but do I really need that? I've been told that lowering the compression like that for no more boost or power than I want to make, will make it a sluggish pig off boost.
Any input would be greatly appreciated!
I can tell You this , any boosted application will blow up with moderately high compression ratio , I'm not sure what the exact #'s are but in general between 8 and 9 to 1 is about the most You want to go . But I don't really know all that much about turbo-ing . If You go to the top of the home page on ls1-tech , there is a button to view all the members , I would go there and pm some of the guys running turbos. Good luck
1999+ LR4 4.8
1999+ LM4/LM7 5.3 Liter Truck
Combustion
Chamber Volume 61.15cc
Compression Ratio 9.5:1
Intake Port Vol: 200cc
Exhaust Port Vol: 70cc
Intake Valve Dia: 1.89-inches
Exhaust Valve Dia:1.55-inches
2001+ LQ4 6.0 Liter Truck
Casting number 12562317
Chamber Volume 71.06cc
Compression Ratio 9.4:1
Intake Port Vol 210cc
Exhaust Port Vol 75cc
Intake Valve Dia 2.00-inches
Exhaust Valve Dia 1.55-inches
Hope This Helps Ya.
Combustion
Hope This Helps Ya.
1999+ LR4 4.8
Combustion
Hope This Helps Ya.
Combustion
Hope This Helps Ya.
Now the questions is, should I Switch to the 317s or just stick with the stock 5.3 heads?
