Oil pressure
Oil pressure
How much oil pressure is to much? I just got my motor done and i feel like its not a enough oil pressure its got a ported ls6 pump wit a shimmed white spring wat would happen if i put a shimmed red spring in it? Right now oil psi hot idle is 20 done changed o-ring twice im 100% sure its not damaged. wat to do shimmed red spring or not?
do u have the red spring? wat type oil are u running
it comes with the red spring installed and im running 10w-30 here is the link of the pump
http://www.lingenfelter.com/mm5/merc...w=&range_high=
