will 243 heads help with a stock cam
Old 05-01-2011, 02:10 PM
vbls's Avatar
Default will 243 heads help with a stock cam
i have a 00 automatic with nitrous, headers and a few other mods. my heads now are the 853. will 243 heads help a lot with the stick cam? ( dont want to do a cam now because the torque converter is stock.)
Old 05-01-2011, 02:32 PM
WS6tx's Avatar
YES... They will help Quite a bit, not only do they flow better stock over 853. they have a 64cc combustion chambers which will raise compression, providing more power n/a and with the gas. They will benefit you even more down the road when you due your cam swap.
Old 05-01-2011, 02:44 PM
mtuggle86's Avatar
I don't think there gonna help you much at all except you'll get a .5 bump in compression. A 2000 stock cam is only .500 lift so its not going to be able to capitalize on the 243 heads better flow. The 243 heads only have limited gains in flow over 853 heads under .500 lift. Id honestly say you'll over pick up 10rwhp and half of that will be because the increase in compression.
Old 05-01-2011, 03:03 PM
1990LSx's Avatar
You will benefit from the head swap for sure and you will add that much more power when you decide to do a cam swap in the future.
Old 05-01-2011, 03:05 PM
VincesSS's Avatar
They flow better and have better compression, they will definately help. Any hp guesses is pure speculation unless they've done it.
I'd cut them .020" to give you a little more and do the lifters and good valve springs while the heads are off so your cam swap down the road will be a piece of cake. Good luck.
Old 05-01-2011, 03:20 PM
intenseblue's Avatar
They will help. Gains will be larger when you cam it. I would not mill them though unless you have them ported. I would spend slap them on as is or use a thinner head gasket for a compression increase. Cost would be the same after paying for a mill then stock gaskets.
Old 05-01-2011, 03:26 PM
180ls1's Avatar
I wouldnt mess with it because of the tuning costs and hassle involved. I would though once you cam it and get a better converter. Personally if you are looking for more power i would up the jet size and maybe pull some weight. That would be very cost effective.
Old 05-01-2011, 03:27 PM
mtuggle86's Avatar
It really doesn't take much to see his gains will be very small unless he has a cam to take advantage of the ls6 heads. The only time hes going to so etra flow from these heads is right at his peak lift from .400-.500. Most people with cams only pick up 15-20 rwhp from stock 243 heads without a cam he's gonna be lower then that for sure. Here's ls6 vs ls1 head flow numbers notice how there's hardly any gains until you go over.450 lift. Most of his gains will be from the increase in compression and a .5 bump is only worth about 5rwhp.
http://www.smokemup.com/tech/ls1.php
Old 05-01-2011, 07:40 PM
vbls's Avatar
ok 2 questions, can i put bigger springs with a stock cam? like .650 lift springs?
also you have to get a tune after a head swap?
Old 05-01-2011, 08:13 PM
mark21742's Avatar
Yes you can go with a heavier spring, but you will want to have ot shined to raise its seat pressure some since they are made to run higher lift....if your going to FI a head swap now is get them milled some and ported before you put them on so you won't need to pull them later to have the work done on them, and like said above I'd do lifters too while you have them off.
Do you need a tune for a head swap? I won't say yes, but you are changing your air flow characteristics crossed the whole rpm range so i'd highly recommend a tune.
If it was me I'd do a converter 1st. This will give you higher gains than just a head swap, but if you need to pay for every tune I'd get all the parts together, install at the same time and then get one tune....it won't hurt your parts to lay on the shelf for awhile till you get everything together.
I agree with the others and don't think you would see much gain with even the best ported heads running a stock cam, but you'd see the gains once you dropped a cam in
Old 05-01-2011, 08:22 PM
groundZ-28ERO's Avatar
i noticed alot of difference with mine,
ported 243's, stock cam
got mine for free from a buddy with a 03 zo6
Old 05-01-2011, 08:24 PM
shawn_c992001's Avatar
Will they help? Yes. Will they help later after a cam swap? Yes.
The springs already being in will help later too, as will a port and polish job.
Old 05-01-2011, 11:29 PM
RoidedSS's Avatar
if you can pick them up for cheap, i would grab them. it will have u ready for your future plans. if you have an idea on the cam you want you could get the heads worked for your future plans. I'll be sending my 243's to AI at the end of fall. Their work is showing some impressive gains. Or, like a lot of people are saying just wait until you have everything and do it all at once so you only have to tune once and save the $400 dollars to have it tuned over and over
Old 05-01-2011, 11:36 PM
mark21742's Avatar
Or if you feel up to doing some learning, buy hptuners for $650 and do your own tuning as many times as you like....or get a friend or two to go in with you and split the cost
I'm still in the " I have noclue what heads to buy" category....but I know I'm to the point that I need them because I'm sure my ported/ milled 241s are holding me back
Old 05-01-2011, 11:37 PM
itsslow98's Avatar
why not do 243s and an ls6 cam? youll see much better results and be able to utilize the stock converter still.
Old 05-02-2011, 12:05 AM
98sivlerbullet's Avatar
I am in the same boat here buddy gave me some 243 heads for free and I am getting a hook up on a tune in mid June. Idk if I want to throw the 243 heads on with a stock ls6 cam for now or wait do ported heads after market cam later. Just flat broke right now if it cost around 200 bucks for all the gaskets head bolts etc for me to put them on ill do it.
Old 05-02-2011, 12:13 AM
180ls1's Avatar
agreed or i would favor a 224/224 on 114 if i was changing cams that way i could save the tuning hassle and have a cam that would make better power. That cam will work pretty good with a stock converter.
Old 05-02-2011, 12:18 AM
buzb026's Avatar
do you have any before and after results from putting just the heads on??
Old 05-02-2011, 12:22 AM
IRONFIST's Avatar
Right now I have 243's on a stock cam car. I picked up a couple MPG from the swap, but also picked up power. My best friend own's a 370Z, before the swap we would be dead even from a roll... now after the 243's and LS6 intake I walk away every time.
How much that is in the quarter I don't know....
Also I have not tuned the car.
Old 05-02-2011, 12:26 AM
Did you do the head and intake swap at the same time? Cause a ls6 intake makes a really big gain for what it is. It felt like night and day deference after my swap on the street and went from 8.7s to 8.2 in the 1/8 after my swap.
Quick Reply: will 243 heads help with a stock cam
