Cam swap question
OK, I'm trying to re-assemble, and it seemed like the timing chain was fairly tought when I pulled it apart, now it feels like it's fairly loose. Any suggestions? It is normal to be a little loose, and I'm dreaming? Am I missing something that I didn't see during teardown?
LS1Tech Premium Sponsor
Just inspect the seal and check to see if it has any cracks or signs of deterioration on the seal. If the seal is damaged, your oil pressure will suffer!
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Yes, this platform always has what seems an abnormal amount of slack.
__________________
