ls1 with h/c/i numbers 434hp/402tq!!
Old 05-03-2011, 09:48 PM
anheuserbusch08's Avatar
Default ls1 with h/c/i numbers 434hp/402tq!!
just got it retuned i have a 98 trans am ls1, a4 with a 3200 stall, 3:73 gears, torquer v2 cam, p&p 243's milled .020 with stock mls gaskets, ls6 intake and i only made 434hp /402 ft lbs of torque. im still on stock 28.8 injectors and i maxed them out. im wondering if its doing good for the mods or do i need to work on other things (other than injectors)
Old 05-03-2011, 09:56 PM
z28241's Avatar
Numbers are spot on! Unlocked stall right? what are the exhaust mods..
Old 05-03-2011, 09:57 PM
ryle's Avatar
Mustang or DynoJet?
Old 05-03-2011, 10:01 PM
it was a dynojet with the converter unlocked exhaust mods are hooker long tube headers to a borla muffler and no cats
Old 05-03-2011, 10:02 PM
z28241's Avatar
not bad..
Old 05-03-2011, 10:05 PM
ryle's Avatar
Old 05-03-2011, 10:13 PM
Wildcobra's Avatar
Wow thats real good numbers
Old 05-03-2011, 10:15 PM
z28241's Avatar
moderator's will prolly move this to the dyno thread fyi
Old 05-03-2011, 10:16 PM
im new at where i post stuff at i just need a lil help thats all. heads are done by myself and tune done by flaco
Old 05-03-2011, 10:21 PM
z28241's Avatar
its all good bro..good numbers as well! take it to the track with some stickys and see what it will do..let us know!! IMO, u will prolly wanna ditch that converter for a 4000..
Old 05-03-2011, 10:24 PM
would it be too much for a daily driver????
Old 05-03-2011, 10:32 PM
z28241's Avatar
That depends on the owner..an performance 3600 would do such as Yanks SS3600..look at your dyno graph, I had a mild 3800 w/ a low str. on the dyno it actually took a slight dip b4 rising..thats with a 236/240 .629/612 cam..u might b okay with ur converter if its a harder hitting str..
Old 05-03-2011, 10:37 PM
garygnu's Avatar
great numbers!do you have a UD pulley or a ported TB?what size lid and MAF?consider a cut out .
Old 05-03-2011, 10:47 PM
z28241's Avatar
Anyhow, those are respectible #'s..stalled A4's show their #'s usually at the track! Good luck!
Old 05-04-2011, 07:29 AM
its a ported 78mm tb (halfass ported) and i have a cutout but its right before the connection to the muffler and exits through the muffler making it almost straight pipe it was open and it has a ud pulley (old steel one one of the early made ones)
Old 05-04-2011, 11:27 AM
98blueSScamaro's Avatar
Killer numbers for unlocked and 243's for the win. and with a ls6 intake
Old 05-04-2011, 02:39 PM
Rare96LT1Formula's Avatar
^ This. Those are awesome numbers for the mods you listed, especially an A4
Old 05-04-2011, 04:16 PM
m1a2d3's Avatar
for an unlocked converter those #s almost seem to high. do you have a graph hows the low end torque. if the car is making that much power you should be very happy.
Old 05-04-2011, 07:38 PM
sorry i had a type o the converter was locked im gonna upload the dyno sheet in a couple of minutes
Old 05-04-2011, 08:46 PM
SOMbitch's Avatar
Almost exactly what my old a4 346 made but I had a 90/90 & UD pulley. 230/234 with SS3600 so I would say thats's pretty strong...
Quick Reply: ls1 with h/c/i numbers 434hp/402tq!!
