My car wont start! Help please
Ok i have tried to research this but i can find out what the problem is.
I have a '02 formula 113k, only light bolt ons.
heres the story... I drive my car everywhere but i started to notice that if I get on hard and run around town or whatever then i stop at lets say at the gas station, when i try to start it up again it wont start. what is the deal is it getting to hot orr what... can anyone tell me whats going on or somethings i should check.
i also have the PO410 check engine light... secondary air injection malfunction.. can this have anything to do with it?
I thought it might be VATS but the security light doesnt come on..
Im assuming it cranks but does not start? If it cranks then it is not the starter. you need to get it hot, cut it off, make sure its malfuctioning and then start testing. I would check for fuel pressure while it wont start, if you have pressure then you need to make sure the injectors are firing, then check for spark. Good luck!!
