Upgrading lifters, is it worth it?
Old 02-23-2004, 03:17 AM
Trans Am 2 N V's Avatar
Default Upgrading lifters, is it worth it?
I am building a 408 is it worth upgrading the lifters or is it a waste of money
Also which ones should I get
Old 02-23-2004, 03:20 AM
blk~2000~Z28's Avatar
If you are going for a wild cam then yes. If you are putting a mild cam without agressive ramps then probably not. I would only think that if you were concerned about valve float i.e. radical cams and upper RPM ranges then you should look into somethine like comp R's.
Old 02-23-2004, 04:01 AM
kumar75150's Avatar
not power wise unless there is problem with the stock lifters
Old 02-23-2004, 04:31 AM
JoSeY's Avatar
low lift cam yes...high lift cam no.
Old 02-23-2004, 04:39 AM
cam is going to be around 242/244 612/612 112
i just want to know if it is worth the $200 to spend while the engine is out or can i just keep the stock ones and spend the money elsewhere, i just want to upgrade now while the engine is out and wont have to go back
Old 02-23-2004, 06:36 AM
Xerxes's Avatar
I would it if I had it to do over again. Who is building the engine? Ask them and see what they say.
Old 02-23-2004, 06:46 AM
LS1Tech Sponsor
Slowhawk's Avatar
If you upgrade to Comp R's you will most likely need an adjustable rocker setup.So $200 turns into $1000.I'll stay with stock lifters.
Old 02-23-2004, 06:49 AM
I think I am going to I cant go wrong, I am goingto go with the Comp R and Harland sharp 1.7 rockers
what are the Comp R v. Comp OEM
Old 02-24-2004, 12:23 AM
Unaffliated Racing's Avatar
the harland rockers aren't adjustable..just pay a little extra and get some good adjustables....comp pro mags
